    Dec 2001
    Montreal, Canada
    Hi,
    I Wanna know if there's a way to re-encode mepg2 svcd to mpeg1 vcd using the mpg files
    is someone have an idea?
    let me know thanks!
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    load mpeg2 file into TMPGenc and load VCD (or whatever mpeg1 settings you want) template and hit start ..
    this is the short version -- be aware that mpeg1 is only progressive output
    Dec 2001
    Montreal, Canada
    OK thanks BJ-M!
    I think I'd forgot to reinstall the MPEG2 codec pack from my last format, did that and it work
    thank anyway, really appreciate!
    Ray
