I just re-formatted my HD, and re-installed TMPGenc, and I can remember before that my captured .avi's (from my dv cam) wouldn't open, so I had to change the priority of something in the Environment settings.
I can't rememer exactly which one is was, and all i've tried haven't helped.. does anyone know what I have to do?? TIA
-- The Newbie GuidesIf you get an error message when opening the video or audio like file unsupported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.Hello.
Best environment for DVD authoring?
By Conrad007 in forum Authoring (DVD)Replies: 23Last Post: 21st Jan 2011, 05:04 -
run application on a dual screen environment
By George2 in forum ProgrammingReplies: 0Last Post: 24th Jun 2009, 13:10 -
Vista Display Environment Problem
By gilesan in forum Software PlayingReplies: 2Last Post: 26th Jun 2008, 08:19 -
Environment lighting issues
By paulosfilho in forum Capturing and VCRReplies: 1Last Post: 17th Mar 2008, 14:00 -
How 2 test a PAL DVD in a NTSC environment?
By Charmed in forum Video ConversionReplies: 6Last Post: 2nd Jul 2007, 20:32
