Hi Guys,
Just wondrin' if any of you people have tried putting together on one dvdr a THX trailer, just the movie, and also a short trailer. A good example is ICE_AGE with all of the mentioned items on two separate discs.
I tried ripping both discs, took the VOB's I needed, renamed them and created a new IFO with IFOEDIT but it didn't work for me. Would any of you have any ideas on how I could accomplish these ???? All suggestions is greatly appreciated, even if you haven't tried it, thanks in advance.
This may not directly answer the question you were asking, but I was able to copy Ice Age and fit it onto one disk while keeping all of the menus, THX trailer, etc.
The way I did it was by getting rid of the fullscreen format VOB's and associated files. (I believe these were the VTS_08_x.* files.) I then copied and renamed the VTS_09_x.* files to replace the 08 files. (I'm somewhat of a newbie, so I'm not sure if that part was necessary, but it works.) Then I just used IFOEdit to "GET VTS Sectors" and then burned the disc.
Works perfect in widescreen format, has all menus, and everything (except for the fullscreen format). If you would rather keep the fullscreen format and get rid of the widescreen files, then I believe those are the VTS_07_x.* files.
- Clipper453
Suggestions on video style for movie trailer?
By lowellriggsiam in forum Newbie / General discussionsReplies: 0Last Post: 17th Sep 2010, 17:35 -
Need Help with Movie Cut Short
By shalini72 in forum Newbie / General discussionsReplies: 7Last Post: 2nd May 2010, 02:02 -
Green Lanter fan made movie trailer
By freebird73717 in forum Off topicReplies: 7Last Post: 10th Jun 2009, 18:54 -
Making a short trailer
By B-Twien Bytes in forum Newbie / General discussionsReplies: 2Last Post: 2nd Oct 2007, 14:38 -
need program where i can take aac in apple movie trailer and make it ac3
By marinerules in forum AudioReplies: 1Last Post: 19th May 2007, 03:17
