Ok,
I'm having some trouble finding the media i need. I have an older DVD player. I've come to the conclusion that it will only play VCD's & SVCD's if they are burned onto a CDR with a dark blue back. I always used the generic Verbatim's & they work perfectly. Well, i went to buy them again (1 year after my 1st purchase of them) and the dye on the back is now light green, and guess what ... vcd's & svcd's do not work. Can anyone help me out here in finding a brand of CDR that has a darker blue back??
thanks in advance!
If you buy the cheap Verbatims they're the same as any other dirt-cheap CD spools you see in the store. The good Verbatims (Datalife Plus) should still have the "Super-Azo" dark-blue dye.
Media Player Question
By gazbag in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Jan 2011, 09:54 -
First time using HD media question.
By ingeborgdot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Dec 2010, 08:34 -
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
Question about + or - DVD media
By OzarkBaby in forum Newbie / General discussionsReplies: 7Last Post: 16th Dec 2007, 18:19 -
DVD Media... NO CDR!
By Lighters in forum MediaReplies: 5Last Post: 5th Jun 2007, 11:26
