I just downloaded 1.4 and the GUI (6b61) for the first time.
I'm trying to encode a wav into an AC3 file.
I set up my source file and output file, and also select BeSweet.exe for the program.
Everything looks good, and when I click on the button to encode Wav to AC3, it says "transcoding" at the bottom, but nothing is really happening.
It continues to say transcoding as long as I don't move my mouse. As soon as I move the mouse, the GUI returns to normal (it no longer says transcoding).
But there is no output file. If I let it create a log, the log is blank.
I tried downloading a seperate AC3enc.dll from Doom9, but it makes no difference.
I don't have a bad attitude...
Life has a bad attitude! -
Is there a better place to post this?
Or is there a tutorial somewhere?
This program converts wav to mp3 just fine, so there must be something wrong in my set up somewhere. But I don't have a clue where to look.I don't have a bad attitude...
problem with besweet while changing 25 to 23976 fps
By montevo in forum AudioReplies: 5Last Post: 23rd Jan 2012, 04:39 -
Bizzare problem capturing - NEWBIE
By Aarell in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2012, 11:38 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 19:37 -
problem with audio using besweet preset ntsc to pal
By Lynxer in forum AudioReplies: 0Last Post: 24th Aug 2008, 12:30 -
Newbie MVI File Problem
By pbmc59 in forum Software PlayingReplies: 4Last Post: 3rd Sep 2007, 09:08
