  1. I recently purchased a new Dell w/a 2 Ghz processor and 512 MB of RAM along with a Leadtek WinFast TV2000 XP capture card.
    I split my cable coming out of the cable box. This way I could record shows off of HBO. To my surprise I fried my motherboard hooking the system up this way. Does anyone know why or how this happened. I just had Dell put a new motherboard in my PC but I'm afraid to try it again.
    Does anyone have a similar setup? Does anyone know if there are problems capturing from digital cable? (COMCAST DIGITAL)??
    Any help or suggestions are greatly appreciated.
    Thanks,
    -niko
  2. Try capturing video using composite or S-Video in if you have it.
  3. It seems VERY unlikely you fried the mboard by having coax into the video card. What makes you think that caused it ? Did u try and shove it in the usb slot or something ? If you're paranoid, use composite or s-vid out from the cable box instead. That just doesn't make sense though.
  4. I had similar problem. It's just probably you checked inside and touched your motherboard with bare hands where they were magnatized at a time and that's why you might have fried it. Check your hands before touching any hardware components.
    =[ vinchi007 ]=
    Dec 2002
    Israel
    It may also be that your CATV Coax Connector shield is not properly grounded at your premise, and carries some relatively low Voltage potential (30V ...) - enough to destroy the board.
    To verify - take a Voltmeter (if you have one) - and measure the Volts potential between your CATV Coax Shield and the casing of your PC. It should read a Solid '0'.
  6. Usually the cable ground is grounded to a water pipe ground where it enters the house. Yes it should read zero volts when measured ground to case of computer.
    I blew up my MPEG card 3 years back doing a similar thing with the vid out to a TV that were at different potentials.
    Panasonic DMR-ES45VS, keep those discs a burnin'
