Seems that people have had luck getting dvd+rws to play on their Apex 600a by changing the bitsetting with the Zuiderwijk utility at http://www.dvdplusrw.org/resources/bitsettings.html. However, when I run it misrecognizes the dru500a as a first gen dvd+rw and says it's a no go. Is this just a matter or waiting for the software author to catch up, should I use something else, or is it a no go?
For what it is worth.. I was wondering the same thing...
I have an older DVD player and was wondering if this might help to get disks to play... -
Sony has not published a means to set the DVD book type, and
the sony drive is incompatible with the method that the bitset
utility attempts. It's not clear if there will be a way to set the
book type on the sony in the future. Sony has yet to even
acknowledge the problem.
Bitsetting compatibility
By davidprosser in forum Authoring (DVD)Replies: 2Last Post: 12th Jan 2011, 14:39 -
Is it worth changing HDD over to FAT for playing on Sony Blu Ray player
By Dankriss in forum DVD & Blu-ray PlayersReplies: 11Last Post: 17th Jul 2010, 20:40 -
Does a Samsung TS-H653N support bitsetting?
By raryke in forum DVD & Blu-ray WritersReplies: 4Last Post: 26th May 2009, 11:54 -
Change bitsetting on DVD Duplicators?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 14th Sep 2008, 14:58 -
Any Pioneer burners do bitsetting?
By kenmo in forum DVD & Blu-ray WritersReplies: 62Last Post: 7th Jul 2008, 23:33
