For a coupla years now i have used TMPGEnc to convert the audio from stuff i've downloaded from .mp2 at 44.1 Hz to .mp2 at 48 Hz..... now all of a sudden when i run the files through TMPGEnc i get an mp2 with no sound.... if i try to use "audioedit" it wont even play the mp2.... i've tried other encoders with the same problem, beesweet also gives me an mp2 with no audio.... i can't remember installing anything, codecs or updates.... anyone ever have this problem / any suggetions??
Any help would be appreciated
Hmmmmm yes i have a similar problem too, im not sure if its to do with the encoding to mp2 but it seems everytime i try to encode and avi to mpg the result comes out with no sound.
I have tried updating my version but it doesnt seem to fix the problem.
If you find out or know the problem and how to fix it can you please post a reply message.
or email hunka_man@hotmail.com -
You should be able to work around the problem using BeSweetGUI, or TooLame. Check your Environmental Settings | External Tools settings to make sure everything is in order. Ensure that if you are using an external program, that the EXE files your pointing to are still there, and have not become corrupted. Try running them manually to ensure they still function as expected. Not to say that Windows isn't a perfect operating system, but files do get corrupted due to lockups, and hardware failures.
If your using the BeSweet GUI, I've noticed that there is a bug in the interface for 2Lame, with two options for Wav To MP2. One gives you a MP2 that's all white noise. The other seems to work as expected. Try a small bit on both to verify if this is the problem your seeing. You can always update your version of BeSweet, or 2Lame as well to see if that helps.Impossible to see the future is. The Dark Side clouds everything... -
I have fixed the problem, i downloaded toolame and then done what the instructions somewhere on vcdhelp told me to do. Every time i convert with TMPGEnc i convert the avi to wav with avi2wav and then it all seems to work fine.
:P
Freeware to mux mpeg-2 (m2v mp2) (NOT TMPGEnc)
By 2397to2997 in forum Video ConversionReplies: 12Last Post: 18th Aug 2010, 16:42 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 03:40 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 17:53 -
aiff to mp2 audio conversion problem...
By huatnee in forum ffmpegX general discussionReplies: 2Last Post: 6th Nov 2007, 12:52 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 22:50
