Is there any way to reduce an avi movie from 1400Mb, ie 2 CDs, to one that is half that. I have joined the two sections together using VirtualDub, but can the next step be done?
Reencode it with divx with a higher compression ratio (lower bitrate). You can do this with virtualdub
how do i do that? Which compression rate should I use? Do I need to do the audio as well?
In vdub select video then compression, select the compression codec you want to use, ie divx, you need to have this installed on your system. Then select configure and enter the bitrate you want to use. To determine your bitrate use a bitrate calculator. You can get one here.
http://www.tomzavodny.cz/program/bitcalc/index_en.php
Why do rippers size down 720xXXX for in xvid dvd-rips even for 1400mb rip
By peaceDOThuxDOTde in forum Newbie / General discussionsReplies: 9Last Post: 11th Jan 2012, 04:51 -
What program can compress videos to 700mb?
By Jmart285 in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jun 2010, 13:22 -
800mb avi; Would want it to go onto a 700mb CD
By mark63534 in forum Newbie / General discussionsReplies: 39Last Post: 28th Feb 2010, 20:31 -
Blueray to a 700mb .avi file
By withmenilu in forum Blu-ray RippingReplies: 1Last Post: 24th Jun 2009, 06:07 -
900mb avi to 700mb vcd
By dck42069dck in forum Video ConversionReplies: 7Last Post: 4th Mar 2008, 14:33
