When I use the tmpgenc wizard, select files etc, then go to the bit to select bitrates & media, the calculated file size is always waaaaaaay to big to fit on a dvd. Anyone else have this problem?
Two possibilities I can think of here:
1) TmpGenc wizard is crap and calculates file size incorrectly (Don't know if this is the case as I never use the wizard)
2) Your source avi has VBR audio. This is know to cause TmpGenc problems with encoding and especially with calculating the length of the video. The solution is to extract the audio to uncompressed PCM using either virtualdub or in this case I prefer goldwave, and using that as the audio source during the encode.
Hope this helps.
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 14:46 -
Tmpgenc 4.0 Xpress vs FairUse Wizard
By herzeleid in forum Newbie / General discussionsReplies: 0Last Post: 16th Nov 2010, 14:10 -
FairUse Wizard error
By dudeman316 in forum DVD RippingReplies: 3Last Post: 21st Jul 2009, 12:58 -
FairUse Wizard indexing error
By PudyCat in forum Video ConversionReplies: 1Last Post: 20th Jul 2008, 12:26 -
Rebuilder Run-time error ‘52’
By coody in forum DVD RippingReplies: 2Last Post: 4th Jan 2008, 11:03
