Let me first tell you that I am completely new in this stuff. Until now I never downloaded or worked with Divx, but I would like to start with it.
Recently I bought a Philips DVDR 890 and somewhere I read a user comment on it, saying amongst others that with that it was possible to play Divx files without the hassle of decoding etc. (or something like that).
Unfortunately I cannot find that comment anymore and I don't know anymore where I saw it.
Does someone know if it is really possible and how you have to do that , or what you have to do ?
I would be very gratefull for any help.
Ton
Results 1 to 10 of 10
It won't play divx
You can play DivX from the computer onto a TV thru a S-video output on your video card if it has one (or you can get one, you can also watch it on PC if you really wanted to, but very most likely, not). Or you get to convert it to mpeg, *VCD or DVD (if you have a DVD burner), which takes quite a while, and then burn it.
Or buy the KiSS DP-450, a Divx compatible DVD player which was supposed to be released in late October.
...which i purposedly didn't mention for it's a piece of sh... See the other 600 posts on it... I'm really tired to say why it sucks every time someone mentions it.
Thank you guys for your replies.
In the meantime I found the following post in the hardware forum at
www.dvd.reviewer.co.uk
RE: FAO John sweeny - Recording from PC To DVDr880
posted by Gurjinder on Saturday, 16th November 2002, 23:37
Sorry for replying so late.
All I done was to connect the TV output from my graphics card to in input on the DVDR and include the sound. so all these will conecct to the front of your DVD player. make so that you can see the output from your pc on the DVD player. So you may have to press the monitor button on your philips remote. Also make sure your pc is set to TV mode and is not still displaying Via yyour monitor. unless you have dual tv out. Run your DivX on your pc and press record on your Philips recorder.
Could it be that it WILL work this way ? Or is this Gurjinder wrong ? -
That is a completely different story! Of course any DVD recorder can record a video signal that it recieves. The recorder doesn't care if it's from a PC or a VCR or XBox or any other video source.
It doesn't mean that it can play DivX encoded video. It will re-encode it to DVD standard, which (as any reencoding using a lossy encoding method like MPEG2) will cause loss in quality.
/Mats -
Yea my VCR can play DVD's using that method
I just connect the tv out of my PC to my VCR and connect my VCR to my TV.
I then play a DVD on my PC and voilla !! My VCR is playing DVD's amazing
Thanks again.
Sounds like I asked a stupid question. I won't do it again
(No, just a joke)
It is all clear to me now. Great and quick help here !
Litlle by little I learn a lot by joining this forum.
Ton
Newbie question.. I have no idea about Divx and all that stuff!
By m0narch in forum Newbie / General discussionsReplies: 5Last Post: 15th Apr 2009, 03:35 -
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 11:57 -
Philips Recorder DVDR 5570 - DIVX subtitles not copied and not displayed
By Radio1040 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 3rd Mar 2009, 02:18 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Philips DVDR 3390 won't let me fast forward DivX movies
By guiri in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Sep 2007, 04:28
