Hi I got two episode of a show I am done editing it but however when I want to join them together an error came up saying both have different frame rate. My question is there any way I can join them because I had try to change the framerate only to found the sound was not in order. or can I do this, turn both of them to mpg with TMPGE then join them with virtualdub? when I change it to mpge with TMPGE does it all have the same frame rate?
Thanx for reading..
<font size=-1>[ This Message was edited by: Mike01 on 2001-08-24 14:23:29 ]</font>
Hi
I have had a few AVI's that were diffrent. I found what the diffrence was and made a new AVI with Vdub to match the other.
However if you use TMPGE and load in a "template", your output mpeg is going to be exactly the same each time.
I use TMPGE and convert the AVI to a PALVCD.mpg ready for disk. A great program for edeting mpeg files is also M2 edit, very easy to join/split my VCDMpeg files.
Vdub can also be used on your now matching mpeg files.
Join .avi files, different video sample rates
By -mm- in forum EditingReplies: 22Last Post: 12th Oct 2014, 06:46 -
Newbie question about frame rates.
By MrTorso in forum Video ConversionReplies: 4Last Post: 13th Jul 2011, 22:49 -
Question about Blu-ray frame rates
By Mentasm in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Sep 2008, 11:16 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 18:47 -
Simplest way to join AVI files with diffferent Sampling rates.
By dagerousdave in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2007, 07:03
