    Nov 2002
    Cali-4-9-Yaaaaa
    Hi,
    I re-encoded an .avi file using tmpg. I adjusted the environment due t a error accepting the file. File plays fine before encoding but after I burned the vcd the video tends to freeze up off and on while the sound continues with no problems. I would really appreciate any help!!! As I would like to add this file to my vcd/dvd collection. I also would like to copy my dad's Star Trek vcd collection too. Do I have to convert the audio to a .wav format before I burn the vcd? I noticed that my riends dvd player will recognize one of my vcd's as mp3 files but it plays fine in my player and its a cheapo Apex. Please some one help me. I will try converting the audio before I burn it this time. Thanks
    Nov 2002
    Cali-4-9-Yaaaaa
    Hi again guys,
    I forgot to say I used NTI CD Proffesional to burn the vcd's and it did give me an eror message thatthe vcd may not play correctly. Could that be my problem and should I use a different burning program?
    Thanks again
  3. Hey there!
    Try to use ULEAD DVD Workshop to make your VCD`s after enconding them with TMPGEnc.
    It`s the only program i use to burn my VCD`s out with. Try it! After a couple VCD`s, you will only swear to this program! ;o)
    Greetings and Ho ho ho from Joze.dk
    Mar 2002
    United States of America
    You can also use VCDEasy or Nero to burn your VCD's after you finish encoding with TMPGEnc.
    Hope That Helps!!! :P
    Nov 2002
    Cali-4-9-Yaaaaa
    Hey jose and puertorican,
    Thanks for giving me advice will try out those programs. Thanks again!
    Nov 2002
    Cali-4-9-Yaaaaa
    I used VCDEasy and only thing wrong with vcd is a slight audio video synch which doesnt matter i guess since it is subtitled . This program worked better than nti. Thanks!!
    Mar 2002
    Good Welcome!!! :P
