Hi! Can anyone help me with the following problem? I want to burn a VCD, the source file is AVI-format. I use the latest version of Nero. I load the file in Nero and conversion begins, then the CD is succesfully created. When I load the CD in my external DVD-player the picture is fine , but there is NO SOUND! Grateful for any help!/Mikael
Never ever use Nero to encode a VCD MPEG. At the most, use it to burn a VCD image.
Take a look at some of the guides under CONVERT for a sample of methods/tools to use for converting an AVI into a VCD.
As for your specific problem, besides Nero, it's probably due to the encoding method of the audio in the AVI. Nero probably can't handle it, so, happily spits out an MPEG without audio. Using the right tools lets you discover and correct this kind of anomalies much earlier in the VCD creation process.
/Mats -
Try TMPGENC to convert your AVI to VCD format (MPEG1). Then use Nero to burn that file.
I have same prob as first post. I've been using tmpgenc 2.57 perfectly for weeks then all of a sudden no sound on mpeg. I upgraded to 2.59 but with same result. the only thing i've added since is a flash player, but thats never given grief before.
Also been lookin for patches just in case someone got to it first but no joy.
??????keef
avi.Net Problem: Not producing an .avi file
By Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 16:22 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 21:27 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 10:57 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
