  1. Hi,
    I've got a .rm file and associated .ram file on my HTTP server. When I'm at work (T3 connection I think) I stream via the ram file and the quality is perfect.
    When I get home (ADSL) I stream the same way but the video quality is very poor.
    I'm using Real Player Basic. Is this due to a setting in the Player client or is it maybe something I set when I created the .rm file?
    I created the rm file using Premiere 6 exporting an AVI to Real Media via EZCleaner 5 (I think - it was a while ago)
    Alan
    universe
    maybe if you gave the link to the file someone could help you
    universe
    Stream: RealVideo Stream - SureStream
    File Name: affection.rm
    Last Modified: Wed, 27 Nov 2002 15:59:17 GMT
    File Size: 11,969,823 Bytes
    Title:
    Author: Real Shocks
    Copyright: ©2002
    Duration: 03:06.204
    Buffer Time: 4.6 seconds
    Max Bit Rate: 225.0 Kbps
    Allow Download: on
    Allow Recording: on
    Perfect Play: enabled
    Stream: 0 audio/x-pn-multirate-realaudio logical stream
    MIME type: audio/x-pn-realaudio
    Max Stream Bit Rate: 44.1 Kbps
    SureStream Audio Codecs:
    8 Kbps Music (RealAudio G2) 8000 Khz
    32 Kbps Stereo Music (RealAudio G2) 22050 Khz
    44 Kbps Stereo Music (RealAudio G2) 22050 Khz
    8 Kbps Music (RealAudio G2) 8000 Khz - for HTTP streaming
    Stream: 1 video/x-pn-multirate-realvideo logical stream
    MIME type: video/x-pn-realvideo
    Max Stream Bit Rate: 180.9 Kbps
    Dimensions: 360x288
    Encoded Frame Rate: 15.0, 25.0 fps
    SureStream Video Codecs:
    26.0 Kbps (RealVideo 8)
    17.5 Kbps (RealVideo 8)
    12.4 Kbps (RealVideo 8)
    117.6 Kbps (RealVideo 8)
    80.1 Kbps (RealVideo 8)
    180.9 Kbps (RealVideo 8)
    26.0 Kbps (RealVideo 8) - for HTTP streaming
    Stream Pairings
    0.0 - 25.5 Kbps
    Stream0Bandwidth = 8.0 Kbps
    Stream1Bandwidth = 12.4 Kbps
    25.5 - 34.0 Kbps
    Stream1Bandwidth = 17.5 Kbps
    34.0 - 112.6 Kbps
    Stream1Bandwidth = 26.0 Kbps
    112.6 - 150.1 Kbps
    Stream0Bandwidth = 32.5 Kbps
    Stream1Bandwidth = 80.1 Kbps
    150.1 - 161.8 Kbps
    Stream1Bandwidth = 117.6 Kbps
    161.8 - 225.0 Kbps
    Stream0Bandwidth = 44.1 Kbps
    225.0 and above
    Stream1Bandwidth = 180.9 Kbps
    Player Compatibility: RealPlayer 8.0 or later
  4. Thanks Secretagent, but what does it all mean? Are you saying that the quality of the stream is determined by the .rm file by figuring out available bandwidth?
