I often download mpeg files, usually in VCD format, only to find that the file contains corrupted frames and audio.
During playback some frames will stick, perhaps display coloured squares, and often the audio will be out of sync and will regularly emit high pitched squeeks!
I've discovered that many of these problems, especially audio, can be rectified by remuxing the file, however this is not 100% successful.
Is there any software I can use that will correct all these types of problems -bad frames, audio and muxing at the press of a button?
Thanks for your feedback![]()
Results 1 to 1 of 1
1080i 25fps to Blu Ray 25GB with x264, problems getting correct output
By Killer3737 in forum Video ConversionReplies: 34Last Post: 17th Mar 2012, 12:20 -
Got a DVD plays correct, copies correct but refuses to write on a blank DVD
By cemman in forum Authoring (DVD)Replies: 16Last Post: 21st Jul 2007, 16:09 -
Codec problems with downloaded avi files?
By aelfheah in forum Video ConversionReplies: 3Last Post: 16th Jun 2007, 08:48 -
downloaded subtitles
By kidTwist in forum SubtitleReplies: 3Last Post: 4th May 2007, 07:20
