is there a way to make an image VCD where you can go through the images by usuing the Skip buttons on your remote? Ive made a slideshow with the Ulead PictureShow software, but it doesnt have this features?
If you use high resolution still images on a VCD, you can author it so that you can navigate between pics with the PREV and NEXT buttons.
VCDEasy can do this (and I presume a number of the other "Photo" VCD authoring proggies would do a similar thing).
http://www.vcdeasy.org
Regards.Michael Tam
w: Morsels of Evidence -
if its like a photo slideshow you want try tmpgenc. it can handle it very well and you can specify how long between frames, so you dont have to use your remote. theres a guide on how to do this on this site.
Your photos won't be in high resolution if you use TMPGEnc to encode the stills into a video sequence.
Furthermore, you still have aspect ratio issues that will not be addressed...
Regards.Michael Tam
I would like you to try DVD Photo Slideshow 1.0. It enables me to use my CD burner to create photo albums. Following only several simple steps, I can easily view photos, create and organize my photo albums, add background music, burn the photo albums on a blank CD/R or CD/RW. After that, I can enjoy my photo albums on TV through a DVD player. I download the trial version from http://www.DVD-photo-slideshow.com I really like it because of its easy-to-use interface.
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
Image PPI -> DVD slideshow...does it matter?
By Grunberg in forum Authoring (DVD)Replies: 1Last Post: 12th Nov 2007, 18:06 -
Using Avisynth Transition PlugIn For AVI Still Image Slideshow
By wiseant in forum Video ConversionReplies: 4Last Post: 24th Oct 2007, 13:45 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
