hello guys i really need help from you!i donyt know what to do any more!plleaaaase.
its about the subtitling issue on how to add and to encode it to vcd!
i have tried to do it from virtual dub is all ok then after i start the frame server and open the TMPEG enc and open the video file saved as *.vdr it displays "ILLEGAL STREAM FORMAT"
these is what i did guys!
1. File->Open and open the Video.
2. Select Video->Filter to configure the subtitler filter. I select ´subtitler-----------Avery Lee and press ‘ok’ which opens the ‘Subtitler: Configuration’ window/box and I
3. Open the the created .ssa file that I have made with Sub Station Alpha by clicking on the ... and then press ‘Show preview’ to check that the subtitles appear on the film. When I am sure they do I press ok under ‘Subtitler:Configuration’ which takes me to the ‘Filters’ window/box where I press ok.
4.This brings me back to the Virtualdub Preview where I see one complete screen with no divisions and no subtitles appearing here, yet they appeared under point three.
5. And now it's time to "Frameserve" the Video directly to TMPGEnc. I select Select File->Start Frame Server.
6. A Frame Server Setup window appears, and when I click Start a save window appears, where I Save the file as anything.vdr.
7. And now this window appears, and it says Frameclients installed: AVIFile only, and I don't click on the ‘Stop Serving’.
8. Now it's time to Encode the frameserved video to MPG. I Launch TMPGEnc.
I Open the .vdr by select Files of types: All files and TMPGEnc. Plus 2.5 version 2.57.41.146, core version 1.90.138 informs me “ ILLEGAL STREAM FORMAT.”I get the same message when I add this subtitle to a video and encode to a VCD/SVCD using Virtualdub, Sub Station Alpha and TMPGEnc. TMPGEnc always informs me that it is “ILLEGAL STREAM FORMAT”.
please guys help im stucked in this mess dunno what to do pls!!!!
I, personally, have never had luck w/frameserving anything from VDub.
you might want to try avisynth--that worked great for me when I needed to serve w/subs.
check this guide:
http://www.vcdhelp.com/forum/viewtopic.php?t=87065what are you askin' me for...
I'm an idiot!
"Video: Stream attributes could not be determined" in Sony Vegas
By bloodshed in forum Newbie / General discussionsReplies: 41Last Post: 6th Nov 2012, 06:12 -
Playing ".pvr" transport stream files in MPC
By uart in forum Software PlayingReplies: 1Last Post: 7th Jul 2010, 18:26 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50 -
corrupted m2ts file - "cannot detect stream type"
By ac1j2 in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2010, 07:51 -
The VOB equivalent of "Direct stream copy" in Virtualdub
By l-w-c in forum EditingReplies: 30Last Post: 21st Oct 2009, 14:13
