is there a easy to do it, or do i have to reencode?
Helo there.
I've just backed it up but had to re-encode to 80% of the original size to get it too fit but the end result came out fine and you can't tel tat it's not original quality at all. If you want to you could try DVD Cloner or one of the other DVD Back-up tools but it would end up on 2 DVD-R's. Or you coud use Ifoedit 0.95 to split it or use Ifoedit to indeed help you to make it smaller.
Cheers
Jimmy
help with star wars saga br
By kn5150 in forum Blu-ray RippingReplies: 9Last Post: 21st Sep 2011, 16:55 -
Star Wars 3D
By stiltman in forum Off topicReplies: 20Last Post: 26th Oct 2010, 19:11 -
Dancing with the Star Wars stars!
By freebird73717 in forum Off topicReplies: 0Last Post: 22nd Nov 2008, 19:55 -
The Last Guy in the World to See Star Wars
By stiltman in forum Off topicReplies: 15Last Post: 5th Jun 2007, 12:31 -
Star Wars: The Legacy Revealed
By JimmyJoeBob in forum Off topicReplies: 3Last Post: 1st Jun 2007, 18:14
