im cappipng from sat so which would be better to cap at. i get good caps at 320x240 or 352x240 but a few peeps told me i should atleast cap at 640x240(+) but when i cap at 640x240 it looks very funny.. loooooong.
That is because you should capture at 640x480 and not 620x240 (unless you just want to resize i horizontally, but I always capture both fields)
Use MMC 7.6 to capture it produces better results:
http://www.ati.com/support/driver.html -
This was asked in another thread...
I suggested 640x480 to get both halves of the frame and I was told I should cap at 740x480 to get there "entire" NTSC frame .--
Will -
What is the final format going to be?
If you're going to end up producing a VCD/SVCD/CVD, then I would reccomend 480X480. I really can't tell a difference, between the results of a 480X480 capture and a 640X480/720X480 capture. Actually, I notice that the 480X480 captures that I do contain less noise.
For me, 480X480 seems to be the best standard, all around capture size. -
This sometimes starts some good debate. I personally agree with mrtristan but take it even a step further. If I'm making a VCD, I cap at 352x480. I rarely make SVCDs but when I do, I use 480x480 and I never use 720x480 because I don't make DVDs. Also, with that 700MHZ CPU, you may find it a bit faster converting from 352/480x480 than 720x480.Originally Posted by willy_annand
Greetings,
Will MMC 7.6 or 7.7 work with the 16MB AIW 128? I have MMC 7.2 and for AVI capture it really sucks! Will this allow me to captur AVIs with 480 lines of horizontal resolution?
Thanks,
Cifcap
best lossy codec for 320x240 video
By videoasker in forum Video ConversionReplies: 12Last Post: 30th Jan 2010, 13:56 -
Why is there no such thing as 60FPS above 320x240?
By Syclone0044 in forum Newbie / General discussionsReplies: 29Last Post: 28th Sep 2009, 15:22 -
3GP with 320x240 not possible?
By ahollmann in forum ffmpegX general discussionReplies: 2Last Post: 22nd Aug 2009, 06:29 -
320x240 mp4
By OG24 in forum Newbie / General discussionsReplies: 15Last Post: 17th Jul 2008, 03:14 -
320x240 res video onto dvd
By scarypoultry in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2007, 17:30
