Hi,
When doing VBR movies, I know it is important for an adverage bitrate and maximum, but is low important? I can set a low point at say 1150 to stop it from droping, but is software like tmpgenc intelegent enough to know only to drop when needed? If not I can see how this is important so it dosn't drop low, expecialy when it misscalculates and really needs the extra bits.
Thanks,
I think VBR kinda sucks I made a movie using VBR and at some parts with no movement that switch to fast movement got all crappy but with CBR it looked better and was faster too.
The newer versions of TMPGEnc doesn't do VBR properly -- I don't know if this has been fixed in the latest versions. The original TMPGEnc 12beta is still probably the best for all versions of TMPGEnc in terms of VBR encoding.
Multipass VBR encoding with CCE is VERY good.
Regards.
Michael Tam
w: Morsels of Evidence
Transcode from High VBR to Low CBR
By AlBurk in forum Newbie / General discussionsReplies: 0Last Post: 12th Apr 2011, 02:49 -
IR CABLE Needed in setting up Media center Advise please
By west403 in forum Capturing and VCRReplies: 8Last Post: 17th Oct 2009, 17:23 -
CCE Luminance setting -- clarification needed
By eclipse95 in forum Video ConversionReplies: 14Last Post: 30th Sep 2009, 10:12 -
Low CPU Intensive video codec needed
By fitch.j in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 04:40 -
Improving this kind of video (low light, trv900 18dB gain, club setting)
By wiseleo in forum RestorationReplies: 10Last Post: 16th May 2008, 09:53
