for some reason my sony DRU wont recongize the ritek DVD-R media i bought (it reads maxell DVD-R fine, thats all i've been able to try). so far, i havent heard of a single person having problems with compatibility, i guess i'm the first. I updated to fireware 1.0d, does anyone have any suggestions to what i can do? i havent changed any of the settings, although i have installed quite a few DVD-burning problems, such as instantvob, nero, and recordnow. i'm all out of ideas any input would be appreciated
thanks
btw its my first post!
I am also waiting for result from g00kster in:
http://www.vcdhelp.com/forum/viewtopic.php?p=382270#382270
Hope you are not dissapointed with your first post!
Thanks for the link! yah i'm going to order some ACCU to test and hopefully it works on my burner.
Does anyone else have a problem with the Ritek on the sony dru-500? or is it just me?
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 04:53 -
Problem with Sony DVD RW DRU-830A
By VOD0708 in forum DVD & Blu-ray WritersReplies: 6Last Post: 10th Jan 2010, 15:43 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 12:52 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 12:00 -
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
