I have TMPGEnc 2.59 and just downloaded m2v_vfp-0.4.6.ZIP encoder. First I don't know how to install it to my TMPGEnc. Second, my TMPGEnc cannot read the m2v files I am trying to open, saying it is unsupported. By the way it is the m2v/mpg file that is 480x480 in dimension. What software do I need to convert this? I want to make it into a VCD compliant mpeg. Thanks in advace for your replies.
Jovi
Results 1 to 10 of 10
recent version: 0.6.17:
http://www.marumo.ne.jp/mpeg2/
Simply copy it to the TMPG directory. (tmpgenc.exe and m2v.vfp must be in the same dir)
I am not sure whether the audio support is stable now.
Start TMPGEnc. and load the video source. Select options > enviromental (global) settings > VFAPIplugin. Increase the priority of the m2v plugin. -
Originally Posted by Truman
Thanks.
Jovi -
LZH is opened by winrar and i think by winace .. theres some free decompressors out there also ... LZH is a good compression format ...
whats this for exactly anyway since mpeg2 support is by powerdvd or ligos?
i mean - is it really nessessary for something , since one can open mpeg files as it ... or is this in replacement of Powerdvd or ligos? -
Jovi -
hmm...I just did a short test with the MPEG-2 plugin and Avisynth. I did it with Avisynth because I wanted to be sure, that this plugin loads the audio and not a different direct show filter (I have installed windvd).
After that it seems, that m2v.vfp support audio quite well.
However, if that does not work for you, demux the audio with dvd2avi (audio > mpeg audio > demux) and decompress it to wav with TMPGEnc.(file > output to file > wav file)
@ BJ_M, yes, it is just a replacement. -
Thanks for all the info and help.
Jovi -
you could have just opened the mpg file in soundforge directly - audio or otherwise...
I got around it in TMPGEnc by using the MPEG Tools and doing a Simple De-multiplex of the .mpg file. Then I loaded the .mpg as the video source and the .mp2 file i got from the de-mulitplex as the audio source.
Transform .m2v +. wav to full MPEG-2 dvd spec file?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2011, 08:13 -
HDV timeline footage to SD (16:9 or 4:3?) NTSC dvd spec MPEG-2 file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 19Last Post: 25th Mar 2011, 06:10 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
