To anyone that helps me........thank you.
I have been fooling around with converting avi files to svcd for a little while....and I have managed to make ONE that is perfect.....For starters..I have to convert to a svcd because my dvd player will not play vcd's.
I download a movie in avi format..normally 2 files.........Here is what I have been doing.......
decompress the audio and save to a wav format using virtualdub........
then open tmpgenc and load the avi file and wav file into it and make a mpg file from it using the svcd template.....
I take this mpg and use ulead moviefactory to author as a svcd and burn it like that....
The problem is that my audio and video are out of sync.....it starts out good..but after about 15 minutes or so........they get BAD out of sync
what gives? please help me out
In virtual dub........the file info on harry potter is
352x288 and 12.5 fps..........I know that for a svcd in ntsc format that should be 29.97fps or something like that...and when I get done..it is....please help me someone.....I have read and read and read.......cant get any help............
Emperor893511@cs.com
Results 1 to 1 of 1
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
