I have captured some video from my Digital * camcorder to the hard drive in the obvious AVI format (4GB per 20 minutes). I have no problem using Tmpeg to encode to a MPG2 file, but CCE states it does not have the proper codec? Anyone ever have this problem?
thanx
tony
Hi
I had to install the "MainConcept DV codec" before I could begin to open any Sony MiniDv-firewire captures on my Pc (aside from Premiere 6 which recognized the file) once I did though, I could use TMPG to encode the file. On the tools page under codec there should be a link to where to download it. Maybe this will help with the CCE encoder, I have tried it out.
Say, how did your Mpeg2 file turn out from TMPG? I'm having a problem with my CBR SVCD encodes from the DV captures- there's always a point on the Mpeg2 file, be it played on PC or on a Dvd player, where the file will skip and stutter after a few minutes. Replaying it again, the skip happens at the same spot. Have you had any results like this?
319
Shouldn't Sony Vegas Pro 8 capture DV avi via firewire?
By brassplyer in forum Capturing and VCRReplies: 6Last Post: 11th Jan 2010, 10:31 -
Sony TVR-460 with FireWire cable 4pin undetected by Sony Vaio Laptop
By vatsyk in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2009, 18:45 -
sony camcorder firewire connection
By rizvii in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th May 2009, 00:23 -
Capture from Sony Camcorder/Firewire connection stopping in 4-12 seconds
By tepeco in forum Capturing and VCRReplies: 4Last Post: 16th Apr 2009, 12:24 -
sony dcr hc30 firewire help
By selinanew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th Jun 2007, 13:19
