I was bever realy looking for capturing device to get my TV shows on PC, but now I have DVD burner and my last visit to CompUSA made me thinking. They have Pinnacle's Bungee DVD for $99. I remebre that it was aroun $200 or more in past.
Is Pinnacle's Bungee DVD good device or would you recomend something else in same price range ? Or why I shouldn't buy Bungee ?
Thanks.
But are you getting the same capture card as the PCTV?
http://www.compusa.com/products/product_info.asp?product_code=293235
So I could spend $30 and use ifoedit/Nero to burn DVDs instead
of the burning program that comes with bungee?
That way I would be $70 ahead of the game............
General Enquirey - Pinnacle Video Transfer USB 2.0 Capture Device
By kato2010 in forum Capturing and VCRReplies: 2Last Post: 11th Feb 2012, 06:53 -
Limited capture success with Pinnacle MovieBox Plus 510-USB device
By ccooper in forum Capturing and VCRReplies: 4Last Post: 17th Jul 2009, 12:52 -
Pinnacle Studio is unable to connect to your video device
By Amyshubby in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2009, 07:30 -
Having problem(s) with my Capturing device
By Adoll in forum Capturing and VCRReplies: 0Last Post: 5th Apr 2008, 12:58 -
What device should I use for capturing?
By Heyjoojoo in forum Capturing and VCRReplies: 4Last Post: 24th Sep 2007, 17:56
NOt even for $99
