Ok when ripping a dual layer disc to dvdr where the film is small enough to fit on a dvdr with out it be re-encoding which way(s) is the best way to go about it.
As this post says one thing http://www.vcdhelp.com/forum/viewtopic.php?t=109346
others are saying use infoedit.
Ive had a butchers at the guides and they seem to ether go around the house's or are just to tell you how to re-enocde.
If it is small enough not to need resizing then you should be able to copy the files straight over after you've removed the encryption using smart ripper. Sure you could tweak things a bit with IfoEdit but do you really need to?
