  1. Thanks Iapin....I have the firmware 7.12 I want the p-code for reg2 pal.....Can i use original remote control to set the codes???
    Jun 2001
    suisse
    The code you need is 055 (pal, r2, 6 audio, pers.colours,beeper, svcd, rgb and s-video).You can enter it with the original remote : play 159 055 000 000 000 play
    But pay attention : you can only change this code 25 times (after it 'will block on the last setting). So it' better to make it with a rc6 rmote (Pronto, oneforall).
    Attention : you 'll also loose the regiofree ability when you 'll change the p-code (but you can make your player regionfree with the sames remotes).
    So, it'up to you.
