It seems to me that when I use a High Quality Motion Search in TMPGEnc, the file size is much higher then when I use Normal. Just yesterday I backed up a 2h 4m movie at 650kbps video, and 96kbps audio with a HQ motion search, and it was well over a gig. When I re-encoded with normal motion search it was 690mb. Whats going on? Is TMPGEnc applying more bits to complex parts? Is there anyway to calculate the file size before hand?
Thanks in advance.
are you talking about "motion search accuracy"???
if you are, then something's not right. i believe that setting a higher quality will NOT increase the bitrate, even though it'll give better quality. motion seearch quality (i believe) searches through the frames and sees if there's anything in common between each frame, so that tmpgenc can save some bitrate. it can then use this saved bitrate to improve quality elsewhere....
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 13:19 -
Removing Weighted Prediction in P-frames
By ad.vid in forum Blu-ray RippingReplies: 4Last Post: 29th Oct 2010, 12:18 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 02:44
