Hey everybody
Sorry my english is not very well because I´m german.
I´d like to convert an SVCD into an VCD
MPEG2 into MPEG1
What for a program do i need?
My DVD Player can only play VCD an non SVCD
HELP !!!
THX GrasHopper
I use TMPGenc to re-encode a SVCD to VCD. Here is how to do it:
1. Go to File--> Mpeg Tools
2. Choose the Simple De-Multiplex Tab
3. For the Input file, you put the SVCD file you want to convert.
4. Hit Run.
It will create a .m1v file - Thats the Video Part
and it will create a .mp2 file - Thats The Audio
After thats done. Close that out and go back to the main part of TMPGenc.
1. In the main window of TMPGenc, load the .m1v file into the Video part
2. then load the mp2 file into the audio part
You may have to choose to see "all files" when browsing for the files.
Then load your VCD template, give it the vcd file a name, and hit Start.
then you have a converted svcd to vcd. -
Another option that may work depending on your DVD player is the 'VCD header trick'. This puts a VCD header onto a SVCD mpeg file and fools your player into thinking it is playing a standard VCD. It doesn't work on all players but may be worth a try. Search the forums for details on how to do this.
I did a search for HEADER TRICK and couldn't find this posting. Could you please post the link for me .... THANKS...Originally Posted by bugster
SVCD 2 DVD Not Working - Cant Add VTS or Click Convert
By rytech in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Feb 2010, 03:55 -
Can't convert avi to vcd, svcd etc...Failed Message
By shankbone in forum ffmpegX general discussionReplies: 2Last Post: 10th Oct 2009, 01:12 -
What is smpeg4 and is there a better way to convert then vcd?
By yoda313 in forum Video ConversionReplies: 12Last Post: 13th Mar 2009, 18:26 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
