ok this is the problem i have a dvd that is 16:9 1:85.1 ratio and 29.970 fps now my question is in dvd2avi how much do you crop or clip so you don't cut out peoples faces. " the dvd is 720 x 480" and should the sides be clipped or cropped or just leave as is. and when reducing resolution how much can you reduce i know smaller is better but i don't want it to small.
also when i put it in dvd2avi it looks like it's fullscreen and it has black bars on the sides and not from top to bottom
I would use DVD2AVI from within Gordian Knot. This way you can visually crop, maintain aspect ratio, and save an Avisynth script to do the job.
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 09:47 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 08:38
