I've used Vegas to create a short VCD both in mpeg 1 + 2 that plays fine in my computer but not at all in my panasonic dvd player.
Do i need a special type of blank CD for video as opposed to the ones I use for my CDRW?
Thanks in Advance
Tim,
You are going to have to give a few more details. But generally speaking, if you DVD player supports VCD and SVCD it should play just about any CD-R and CD-RW on the market. Re-check your DVD player specs to ensure VCD and SVCD compliance.
Also, what were the resolution and bitrate (audio and video) used to encode your VCD and SVCD? Which model Panasonic do you have? If it was not standard your DVD player may not play it.
Sony Vegas how to make this effect?
By wingfan in forum EditingReplies: 0Last Post: 16th Jun 2011, 11:53 -
How To Make Vegas Movie Studio Platinum 10 Use More % Of The CPU?
By JohnnyGalaga in forum EditingReplies: 18Last Post: 30th Jan 2011, 20:19 -
Editing .264 video from mini-cam in Vegas: Vegas won't read video
By bigass in forum EditingReplies: 3Last Post: 27th Dec 2010, 11:35 -
Sony Vegas Pro 9 Q: How do I make smooth slo mo?
By LoveMyslf in forum EditingReplies: 9Last Post: 14th Jun 2009, 17:49 -
SOLVED Vegas 8.0, how can I make a light bulb flashing?
By sdsumike619 in forum EditingReplies: 2Last Post: 25th Apr 2009, 17:21
