  1. Hey all--I rather just use Nero but I have had problems w/it lately (in the encoding process it stops at 84%--even w/different files--I get an error such as, "Nero has caused an error in blah blah--try restarting your computer--Ive done this as well as reinstalling Nero and to no avail)--Anyway so Im now trying TMPGEnc to encode and then burn w/Nero. The problem is after encoding w/TMPGEnc the file is larger than when I started and too large to burn on a disk (and this is only part1 of my file and should have no problem fitting on a cdr)
    This is my example: The file size before I split: 693, 393, 408 bytes
    The file size after split of part 1: 349, 000, 000
    The file size of part 2: 344, 000, 000
    The file size of just part 1 after encoding w/TMPGEns: 752, 422, 916
    Any help is greatly appreciated
    thanx
    jeff
    May 2001
    Ramstein, Germany
    a 80min cd-r can hold 811mb of video or audio not data. so it should fit just fine.
