First some background. I currently own a GForce4 VIVO using the philips SAA7108E 9bit encoder chip and a cheap bt878 card. The philips chip provides a much cleaner and better looking capture than the bt878. Unfortunately, bright scenes become completely washed out and there is no driver support for whitebalance. the bt878 picture is noisy and not quite as good as the philips (when it is working correctly) most likely quality of the bt878 card is to blame. I am using current drivers for the GF4 and modified drivers from this site for the bt878. The quality difference can be seen before and after conversion to SVCD. I am trying to cap VHS home movies and broadcast TV.
now my question, after dealing with these 2 boards, I am contemplating moving to an ADVC-50 or ADVC-1394. Does anyone know what bit per pixel the canopus product uses... 8bit, 9bit, etc. any info would be appreciated.
Results 1 to 1 of 1
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Capturing with Canopus ADVC
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2009, 22:55 -
Canopus ADVC-55 vs. ADVC-110
By bcags7 in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2008, 16:15 -
Canopus ADVC 110 video out question
By Darkestred in forum Capturing and VCRReplies: 5Last Post: 3rd Aug 2007, 23:12
