Hello, what do i need for program to convert from mpeg4 to mpeg2.
My problem is that i can't burn a VCD or S-VCD disc from a mpeg4-file,
must i re-encod or what??
Best regards Sevrool
Results 1 to 9 of 9
You need to encode to mpeg1 for vcd or mpeg2 for svcd. To do this use TMPGEnc. See the how to convert guides.
You probably dont understand my question. I know how to use TMPGEnc, but what i can't figure out is to convert a mpeg4 to a mpeg1 or mpeg2.
avi, divx and xvid are types of mpeg4 compression codecs
Ok, i understand, but why can't i burn my file xxxxx.mpg with CDRWin 5 or easy cd creater. Can it be a newer version of mpg or i miss somethings in the settings?
http://www.vcdhelp.com/tmpgencsvcd.htm
just follow the guide - remember to follow the part that says
"Note 1! If your source is DivX,ASF or SMR it is best to extract the audio separate to a wav with virtualdub because the audio source is often in vbr format which tmpgenc can not handle that well(causes sync problems). "[/quote] -
Sorry i don't understand, my file is already a mpg but i can't burn it.
Need more help please... -
is your mpg a mpeg1 or mpeg2. your software must support burning of mpeg2 (supervideocd) in order to burn it.
or you can try to burn it as a non standard videocd. not familiar with your software, i use nero instead.
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 13:04 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
program help
By Kanyeeeze in forum Newbie / General discussionsReplies: 0Last Post: 23rd Apr 2008, 09:16 -
What program do I use?
By adrian2055 in forum EditingReplies: 8Last Post: 6th Apr 2008, 03:50 -
What is the name of this program?
By innovyse in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2007, 18:41
