Since a long time I've had recorded with my capture card(Pinnacle Studio DC10+)from my VCR(VHS tape) with no problem (I use NTSC System). In time: it's a good capture card.
Well, yesterday, for the first time I did try record direct from my TV(NTSC System too) and the software that came with the capture card opens a dialog-window: "I CAN'T LOAD". I didn't get capture nothing and imediatelly my PC freeze and I need reset it. What's wrong?
Tks for help me.
Have you tried uninstalling the pc10+ software and reinstalling it.
i just bought the same card. How do you get it work properly.
I can't get any video when I convert it to .mpg with TMPGE
what settings are you using..
thanks
Look, one solution could be to update all the software: Studio DC10+ (www.pinnaclesys.com), DirectX(somewhere in microsoft) and the drivers of your video card (Nvida, Vodooo, ...).
Maybe some registries were modified. -
I have the same card, and I got that problem too after using the card for sometime,
I tried uninstalling and updating the card,........but in the end, the only way I found to fix the problem was to formatt -
r_macfarland,
I believe you are using a fairly current version of TMPG?
like say one that's after version d, correct?
I experienced this problem a long time ago, to fix it, you can do one of 2 things,
1) use tmpg d, I find that it works really well,
2) open the tmpg version you are currently using, click on the option menu, goto environment settings, and click on the tab "VFAPI", and give your avi's a higher priority,
this should solve the no video question......however......I found when doing this tmpg would not encode like the last 5% of my videos......
so, all in all, I would recommend the first option
hope I was able to help
Trifu,
1) Options/Environmental Settings/ click VFAPI plug-in TAB
2) right click "AVI VFW..." and select "Higher priority". Keep doing this till it's at top!
You should now be able to see your video in TMPGEnc's window and be able
to encode (and see video in the .mpg file).
Good luck!
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
Software for S-video output on Pinnacle DC10 plus card(XP)
By Eightbitgnosis in forum Software PlayingReplies: 2Last Post: 30th Jan 2010, 10:33 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 22:44 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 11:02 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 23:48
