I am trying to get a 45 min prog onto a dvdr using ulead dvd workshop.
I have my mpeg2 file on the desktop. It plays ok in sync all the way through using media player. When I create my menus in ulead the audio is still in sync. I then create a .iso file. This is then burned to a dvdr on pioneer a03. The disc plays ok but after 15 mins the lip sync starts to go. By the end its about a second or more out. Anybody know what the fix is??
Is it to do with I frames or something?
Check to see if you are using DVD workshop version 1.3, if not download the update from ulead and install it.
In the burning window there is an option that turns of the re-encoding of compatible mpeg files which should be checked. -
Its me.......I just got the patch from ulead.......still dont see this checkbox you are talking about...help
Oops, sorry for the late reply, I missed this one.
Did you solve the problem? If not and you upgraded to version 1.3 then it should appear when you "Finish", the project and burn to disk. Note, it logically doesn't appear if you select "Burn From Disk Image".The Unofficial VMagic Support Site
http://vmagic.unimatrixhub.net
Ulead Video Studio 11+ DVD Burning takes very long time
By chrayf in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2012, 14:43 -
mkv conversion to dvd sync error
By wolfdogg in forum Video ConversionReplies: 8Last Post: 8th Feb 2012, 10:02 -
Sample error on separate source means video & audio out of sync!
By christowe in forum MacReplies: 3Last Post: 13th Jan 2009, 13:22 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 02:55 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 09:40
