Why does VirtualDub, in Capture/Capture Settings, default to a frame rate of 15.002? I keep changing this to 25 (for PAL) am I missing something here?
Pat
Yes, you don't save your set up...
Read the guides!!! There are all there. -
After you have set your framerate. Click on capture -> preferences -> and tick save current capture settings as default. Its also probrably a good idea to save your audio and video format setting as well (if you use the same setting a lot)
Arrgh!! The old "When all else fails, read the manual" trick, huh?
Should have spotted that, thanks guys.
I have another one under "Burning" if you are interested
Frame rate question
By bergqvistjl in forum Video ConversionReplies: 2Last Post: 3rd Mar 2012, 18:09 -
PAL frame rate question
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 15Last Post: 27th Dec 2011, 22:38 -
Frame rate question
By janlafata in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2009, 19:37 -
Video frame rate question
By Ramza126 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2008, 19:57 -
hd-dvd frame rate question
By ultraman36 in forum DVD RippingReplies: 6Last Post: 29th Dec 2007, 10:47
