i just bought a box of these from compusa and they won't read in my burner on my computer. i know why they won't work there.
my question is when i use them in the amoisonic vdr2000 they read as 80min/700mb discs not 99min/850mb. does anyone have any experience with the vdr2000 and know how to tweak it to read these discs correctly?
Results 1 to 11 of 11
The only way you'll get your VDR to recognize these +90min CD-R's is via firmware. If Amoisonic don't release one I think you're stuck. Try contacting them (I believe their main offices are in Hong Kong) via their website.
Adam Electonics seem to be offering their own version of the VDR2000 - you might ask them for a firmware upgrade. -
Is there any update for the VDR2000 available
or is there a way to use a DVD-(R)W or HDD instead to overcome the limitations?
Since I still use my VDR2000 I search on regular base and only found an article about firmwareprogramming but not intended to increase storing time so far.
While there might have been one I don't know since I can't read chineese at all.
90/99 min CDs are (at least have been) always reported as 80 min by the burner. Just look at them as 80 min CD-Rs with a good capacity for overburning.
/Mats -
what he said i have dealt with 90 min cds and that is what i had to do was to overburn because it only showed up as 80 min cd in nero......Originally Posted by mats.hogberg
To use 90/99 minute CDR's both your CDR burner and your burning software must be compatible with overburning. I don't see your burner even listed in the CDR section. Is it overburn comapible?
I noticed the same about 90' CD,
but I am just looking for a way to use the encoder to get longer streams.
I would be willing to buy a DVD-(R)W or a HDD and format it to whatever is needed (some claimed that DVD-player could use a HDD with Linux partitions but have not read anyone reporting about it) for this purpose. -
??? What are you trying to achieve?
/Mats -
To use the VDR Hardware as grabbber for several hours at a time not just 37`. Preferably to be able to use it directly to stream to my PC/a HDD
The quality is acceptable for me just the 37`is to short and I don't like beeing forced to use a VCR to buffer it so I don't miss anything.
I have tried several external grabber with USB-1.1 +2.0 to replace my VDR but was not to happy with the results. -
...and this has what to do with 90/99 min cds?
/Mats -
It was the only time someone was interested in the VDR2000.
I hoped the one owning the same VDR would know.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 22:00 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 06:33
