I am using TINRA to convert a real media .ram file. I am having lots of audio/video sync problems. I have noticed that some codecs turn out different .avi's (some have really choppy picture or slide show effect or are very pixated). I was wondering if someone could recommend good codecs for converting real media files w/ TINRA that would have good pictures and maybe even solve my audio/video sync problems. Thanks!
they recomend divx on various forums that deal with that app ... RM converted to anything looks like crap IMO though ...
thats just a personal view ... -
Well, I've tried the divx 5 and I get mixed results. Sometimes it's great w/ this particular file it's not so great. Thanks for the help though.
have you tried eovideo? i have had a LOT better luck with it then trina
most of my conversions using trina were way out of sync, but eovideo actually does a pretty decent job -
Yep, I have used EOVideo. It did a wonderful job on the other real media files I needed, but it can't do this one either. I just prefer the TINRA because it works so much faster the EOVideo for some strange reason.
Recommend a <$100 capture card for analog to lossless AVI codec
By Cheesyii in forum Capturing and VCRReplies: 8Last Post: 27th Dec 2011, 08:49 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
Recommend an all-in-one.
By Poppa_Meth in forum ComputerReplies: 12Last Post: 9th Feb 2008, 10:41
