i have a Pioneer204 in a generic USB2.0/Firewire case (newegg).. whenever i try to play regular store-bought DVDs via PowerDVD XP (came with the drive), it only gets about 5 or 10 minutes into the movie before the window gets filled with garbage and the movie finally stops.. i have to force PowerDVD to close, and can't restart it until i eject the DVD.. i've emailed Cyberlink about it, and they say i need to make sure i activate DMA access to the drive, but i can't find anything in the control panel to do that.. i have the same problem if i use the regular dvdplayer.exe that came with win2k..
before i was forced to put the drive into an external case and had it hooked up via ATAPI, it everything worked fine..
any help appreciated, i want to watch movies!
win2k sp3
P4 2.53Ghz
2G ram
geforce4 ti4600
built-in firewire and usb2.0
dvd hooked up via firewire
-Matthew
Results 1 to 1 of 1
Raid 1 Firewire external drive, need to use on Mac AND Windows 7
By apollo1980 in forum Newbie / General discussionsReplies: 6Last Post: 19th Jan 2010, 14:00 -
Problems putting a NEW Drive in an OLD External firewire box?
By phase52001 in forum DVD & Blu-ray WritersReplies: 3Last Post: 30th May 2009, 21:03 -
DVR --> PC Hard Drive (Firewire, USB?)
By CaZeek in forum DVD & Blu-ray RecordersReplies: 0Last Post: 31st Aug 2008, 17:58 -
Playing avi file through firewire
By hoodleehoo in forum Newbie / General discussionsReplies: 15Last Post: 20th Aug 2008, 23:05 -
Do they make 5.25 drive firewire enclosures for bluray etc?
By yoda313 in forum ComputerReplies: 4Last Post: 20th Dec 2007, 17:16
