  1. Here's something I don't understand: I am capturing via S-Video feed off of DirecTv. This should give me almost the best quality feed (next to component video) possible. Even so, though, isn't all non-HDTV video in a 352x240 or so format in NTSC? That being the case, what difference does it make if I capture at a higher rate? Why would that give me a better capture. It would seem to be the same thing as getting paid in pennies each week. Yeah, I have more pennies (pixels) but they add up to the same thing.
    Am I just missing something here? I realize the loss in quality mainly occurs during compression. Therefore, if I capture uncompressed at 352x240, isn't that as good as it gets and anything else just muddies the water? Why use 480 x 480 on a normal television show?
    My theory is, capture uncompressed at native resolution and then compress the original until you get what you're happy with. Eh?
    Oct 2002
    Huntsville, Ontario, Cana
    NTSC is actually 352x480. It is interlaced to 352x240 and each frame has 1/2 the picture.
    Will
  3. NTSC is actually 480 analog horizontal lines. generally, it is spec'd at 720x480 or 704x480 digitally, which correlate pretty well to the number of pixels in horizontal scan line of a tv set.
    the horizontal resolution really correlates to the frequency response to an analog signal that a tv is capable of displaying.
    [/code]
  4. yup, NTSC is definately 720*480, capturing at 352*480 will give a significantly more dull picture. if possible ALWAYS capture at 740*480 you can always resize later. Some say it overkill to cap at 720 for VHS but I disagree.. Capturinf at 740 will ensure you get the full badwidth your iinput is capable of recieving, regardless of the source.
    I personally can see a dramatic increase in quality on all capture sources.
  5. Well slap me and call me uninitiated! That's awesome. I will have to try some higher bandwidth captures and see what happens.
    Now, this brings me to another question, then. Shouldn't I get a sharper picture from DirecTv if they introduced a progressive scan receiver / they put out a non-interlaced signal? Or are most shows broadcast from the source as interlaced? I'm aware that more and more shows (newer ones) are being filmed/shot at higher quality. But what about reruns? Were they actually stored to tape in some sort of interlaced format.
    I guess I'm just curious about the source(s) and what the possibilities are. I would think that, given DirecTv (Dish Network) controls their environment a bit more than cable companies (shooting raw info to the decoder for the decoder to decide how to spit it out), they should be able to produce a better picture to a multi-sync tv like a big-screen. I have a Hitachi 60SDX that's a real bad boy but I can tell with normal tv I'm not getting all there is to get, if you know what I mean.
    Comments are much appreciated. I've learned more in one post than an hour of 'googling' the web.
  6. Oh, one other thing after re-reading the posts again. If each frame only contains half the picture, how is capturing picking up the other half?
  7. Member solarfox's Avatar
    Aug 2002
    Yes, older TV shows that were originally shot/edited on video were recorded in an interlaced form on the videotapes. (Which doesn't mean they couldn't be de-interlaced by the broadcaster later, if they were to be rebroadcast over a progressive-scan satellite-TV system.)
    Because willy_annad is confusing frames with fields. A frame contains the entire picture, made up of two fields. One field contains all of the odd-numbered scan lines, the second contains all of the even-numbered ones -- so, each field makes up 1/2 the picture, and when combined together they make up one complete frame.
  8. Oh god. Capturing at 640x480 is a good thing (or 720, whatever), but you don't get that many "real" pixels.... Many in depth posts and articles about it. NTSC calls for lines, not a resolution, D1 is 720x480... Not quite the same story. Also, I've recently had feeds off my satellite with only one field, leaving me only 240 useable lines (and letteboxed, that is)....
