Hi All,
I couldn't be able to play avi with ac3 format any more ... did lots of
searches here without luck!!!
I used GSpot to "locate" the codec .. it said "ac3 (0x2000) "Dolby Laboratories, Inc" " and the codec IS not installed!!! I couldn't find such codec here .. tried to reinstall divx, xvid totalpack ..ect... without luck!!
Any1 care to help me out?
dowload NIMO Codec pack and there is the ac3 audio codec in it you can install.....I am having a similiar issue and this seems to be the remedy eventhough I have had no luck bc I still get no sound!
install powerdvd or windvd (even demo versions) and it has full ac3 support even for divx's
i got some support files for playing avi's in WMP or any player that plays avi's with ac3 sound, pm me if you need it
Output of both m2v AND ac3 during single "Render As" event in Vegas?
By Smells_Like_Feet in forum EditingReplies: 3Last Post: 28th Oct 2011, 19:08 -
DTS to AC3 "static" on recent MKV's
By satviewer2000 in forum AudioReplies: 2Last Post: 24th Oct 2009, 01:23 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 00:10 -
Dolby Prologic IIx. I understood that it will "create" a surround
By andrema71 in forum AudioReplies: 3Last Post: 6th Jun 2008, 10:22 -
Sony HT-DDW990 receiver - why display says "dolby digital 3/2.1"
By buzzinhornets in forum Off topicReplies: 6Last Post: 8th Aug 2007, 18:25
