I have used Sefys newbie conversion guide to make my first DVD-r, but Im having a problem burning....
I have ripped with decripter
I have used DVD2AVI
I have used TMPGenc
I have used IFOedit all successfully now I want to burn to disc but when I drag and drop into my new DVD folder and try to burn I get a massage saying "DVD-video files reallocation failed. The DVD-video maybe unplayable?
Can anyone help please
Well I really don't know why you are using all those programs??
I was having trouble buring my first DVD-R using like 20 differnt programs and none of them work. As of now I just use Smart Ripper and Nero.
1. I load DVD into DVD-Rom.
3. Before I actually rip the DVD I make a specific directory for this DVD movie
2. Then I start Smart Ripper. Smart Ripper automatically reads the DVD and gives you 3 option.
a. Rip only the Movie
b. Rip Certain files of the Movie
c. Rip The entire DVD
3. I usually select option c if it's under 4.7 G. Choose your targetted directory - the one that you made in step "3".
4. Once ripping is complete just open Nero and chose DVD-Video.
drag all the files in the directory and move them into the VIDEO_TS directory that Nero has set up for you. Hit the burn button and let it do it's thing.
* This of course only works for movies 4.7 G or less. For movies that are more than 4.7G then you will need IfoEdit. I have instructions for that too.
** If you have a CD Burner - make sure you have the DVD Burner choosen in the Nero Settings. There are some people that forget to choose back to the correct writer.
Let me know if this is any help......you can e-mail at
gin_32@yahoo anytime for more help....
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 12:24 -
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 20:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 14:40
