I installed the virtualdub handler and then ran a frameserver for a divx movie from vdub. I then tried to open the frameserver with tmpgenc and it opened fine, but when i try to encode it gives me the error "Illegal floating decimal point calculation order." Can someone tell me why its doing this and how to fix it? thanks
-- The Newbie GuidesIf TMPGEnc freezes or crashes when converting or you receive errors such as
Unexpected decimal point calculation
Try first to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.
Or try to convert the audio to wav before converting(If you have problems extracting the audio using Virtualdub try use Goldwave or AVI2WAV).
Or try to repair the AVI,DivX or the ASF.
Or try to use avidefreezer to fix your video source.Hello. -
OK i got it to work but now my encoded file has screwy sound, it will play a second or 2 then repeat it once or twice, then play the next second or 2 and so on.. how do i fix this?
Did you extract the audio and save as a WAV using Virtualdub?
"Today is only yesterdays tomorrow" -
OK that works now, but this movie i have to split into 2 parts and the second part has bad audio synch, but the first part is fine
If you still have the original DIVX.
Extract the whole audio as WAV with Virtualdub.
Then enocde with TMPGE and use the source range and batch encode to split the movie during the encode process.
If you are not sure of these process'....let me know."Today is only yesterdays tomorrow"
Frameserver for Premiere Pro cs4 64 bit
By helionfilm in forum Video ConversionReplies: 3Last Post: 6th May 2011, 08:13 -
Virtualdub frameserver error
By AwesomeRickyC in forum Video ConversionReplies: 6Last Post: 5th Jul 2010, 14:34 -
Can't navigate mpeg-2 output from TmpgEnc (VurtualDub as frameserver)
By Alex.the.pretty.good in forum Video ConversionReplies: 2Last Post: 3rd Mar 2010, 14:28 -
Debugmode Frameserver questions
By vid83 in forum Video ConversionReplies: 5Last Post: 31st Dec 2008, 18:52 -
Alternate to debugmode frameserver (for Premiere Pro 2.0)
By foochuck in forum Video ConversionReplies: 6Last Post: 13th Jul 2007, 08:05
