  1. I have tried to make a vcd from a DVD-Video with DVDx 2.0 and TEMPGEnc 2.59.47.155. I used the "DVD Backup without having 8GB free" guide on VCDHelp.com, but this guide uses older versions of the software. Can anyone point at newer guide with the same content, but updated for DVDx 2.0 and TEMPGEnc 2.59? Or help in any other way?
    Shoud I use other software than these two at the same time?
    Thanks in advance
  2. I'm a bit confused...
    If you used DVDX to encode...then why do you also need TMPGE ?
    "Today is only yesterdays tomorrow"
  3. Because TEMPGEnc encode with much better quality, I have heard.
