if its interlaced u encode with interlaced,, etc ect
what i want to know is, how do i find out if a avi file or a mpg file iver downlaoeded is interlaced or not?
You should be able to tell by watching it.
Huh? I'm still a relative newbie, but I'm pretty sure it's impossible to identify interlacing with the naked eye.Originally Posted by craigtucker
http://www.puremotion.com/videoediting/reference/technical/whatisdeinterlacing/
check the first image. If you play a mpeg2 with powerdvd or windvd it will automatically deinterlace so you won't se any interlace lines, play/preview with dvd2avi instead. An avi can you check with virtualdub. -
if that pic of him on the left is really him he aint 1 of us lol
"jokes".... seariously i thought the same too
Those lines your seeing is from the hair all over your fuzzy head chewwy, not interlacing.
That's an old picture, I've had a trim since then
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 23:09 -
Interlaced.... or not?
By pgoelz in forum Capturing and VCRReplies: 29Last Post: 15th May 2011, 23:20 -
Interlaced or not
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 26th Oct 2010, 10:17 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 10:16 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 19:48
