Results 1 to 10 of 10
    May 2001
    Argentina
    Can TSCV v0.7rel2 only generate SVCD ?????
    (I know that I can edit the XML and change it from SVCD to VCD)
    Regards,
    Miguelo Perez
    Argentina
    May 2001
    Argentina
    Anybody knows??????
    Thanks...
    Miguelo Perez
    Argentina
  3. It wants the CDi applications (like 3 files) to make a strict VCD. The files are on the VCDimager site I think. It's in the documentation.
    Da Kitty
    May 2001
    Argentina
    Anybody can help me ??????
    TXS.
    Miguelo Perez
    Argentina
    Feb 2001
    Berlin, Germany
    Copy TSCV, VCDImager and the CDI files to the same directory. TSCV is still in development. v.07 is not the latest, some versions are buggy. I know,that v.072beta rel2 create VCD images.
  6. You must have a CDi folder in the TSCV folder. You need the folowing files: CDI_IMAG.RTF, CDI_TEXT.FNT, CDI_VCD.APP You can download these files at www.icdia.org/sw_app/vcd_on_cdi_411.zip or copy it from a VCD, or get them from Nero.......
  7. By the way, the newest version is 0.72 rel 7.
    It has a still- and motion-menu generator.
  8. It is not up for download on your site. When will it be available???
  9. Never mind I did find it... Sorry
    May 2001
    Argentina
    OK. Thanks to all of you who helped.
    CASE SOLVED!
    I've downloaded both new TSCV (anyway) and the folder CDI (which solved my problem).
    TSCV & VCDIMAGER are GREAT tools.
    Miguelo Perez
    Argentina
