Hi
I have a problem with DVDx 2.0 and TEMPGEnc 2.59.47.155. I have tried to use the "DVD Backup without having 8GB free" guide found here at VCDhelp.com. But when I press the "browse" button for video source, I got this error messege: file ... can not open, or unsupported. I was trying to make a vcd from a dvd-video.
Any help is appriciated
Thanks in advance
Also IPCsource is no longer part of Avisynth. Which version do you use?Originally Posted by the guide you have mentioned
I only use the two mentioned software (DVDx 2.0 and TEMPGEnc) and VideoServerPackage0951.zip
Well, you said, avs is not supported. So you use the Avisynth mode of the server plugin. So you have to install Avisynth and AvisynthEX.dll too.
http://www.videotools.net/index.php?rub=guides&htm=intro2pvsp.htm&PHPSESSID=c5db80a413...57b44cb5e939a9
Otherwise you may use the Wrapper mode.
http://www.videotools.net/uk/installation.php
http://www.videotools.net/guides/guide_testing_the_wrapper_client.php
Avi not divx-supported size?
By chirufan in forum SubtitleReplies: 21Last Post: 8th Mar 2008, 05:35 -
Help Friend! How to read subtitle file on my dvd player (not divx supported
By justin1983 in forum SubtitleReplies: 17Last Post: 26th Jan 2008, 12:42 -
Is there a list of supported resolutions for DivX certified DVD players?
By quitearush in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2008, 06:26 -
problem with tempgenc plus
By lancerx in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 02:35 -
Is there a list of all supported files supported by svcd2dvd ?
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 19th Oct 2007, 12:07
