hi im trying to compress a .mpg file so that i can put it on a cd but its a bit too big to fit on a 700mb cdr. the mpg file is about 766mb. so what i plan to do is maybe use virtualdub to compress it down a bit. but everytime i do so i get a sync error. anything i can do to fix this or any suggestions on compressing .mpg?
Well, first, a 700 MB CD will hold 800 MB burned as VCD or SVCD.
Second, Vdub does not do MPG compression.
Third, I would suggest reading some more. -
if your trying to burn your mpeg file as a vcd or svcd to watch on your dvd player just read here . you can burn 800mb to a vcd or svcd.
http://www.vcdhelp.com/author -
yeah i meant compressing it to .avi to try and lower the size.
anyways thanks for the suggestions, ill try burning it as a vcd/svcd.
Subtitles without re-compressing?
By sergiozambrano in forum Authoring (DVD)Replies: 3Last Post: 9th May 2010, 22:22 -
Virtualdub output to mpg?
By zakman in forum Video ConversionReplies: 25Last Post: 5th Feb 2009, 09:48 -
VirtualDub can't open my mpg from camcorder
By ssalim in forum Video ConversionReplies: 3Last Post: 2nd Dec 2008, 16:46 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
best format/codec for compressing an mpg???
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 19:31
